Full Version: new radio
dixie t.
put new radio in my 72 . i need a wire to keep the clock and settings on ? where can i hook it to? the radio manual said to a aux. line. what can i do, help. thanks cheer.gif driving-girl.gif
Mueller
QUOTE(dixie t. @ Jun 15 2016, 07:18 PM) *
Basically looking for a line off the fuse block that is hot when the key is not in the ignition (and make sure the amp rating is within what the radio will demand, that should be in the manual)
Mark Henry
If you listen to your radio with the engine off then you want both the main power and aux hot all the time.
PITA as you have to manually turn off/on your radio all the time, but the 914 ignition switch has no accessory and you will burn out your points and older ignitors, if you leave your key on without running the engine.
dixie t.
thank you mark and mueller. i will look for a low volt line off the fuse box. dixie stay cool.
Mueller
QUOTE(dixie t. @ Jun 16 2016, 03:20 PM) *
Not sure what you mean by low volt...
You have 0 volts or 12vdc (okay, it might be 13ish smile.gif )
Did the car not have a radio at all? Good chance the old harness is still up there if you have not looked yet.
