72SD914
Jun 16 2016, 09:38 PM
I'm in the process of gathering parts necessary to install a side shift transmission into my 72. I'm in need of the Drivers side warm air guide and two outer engine bar mounts.
boxstr
Jun 17 2016, 07:14 AM
Good morning. Are these the mounts you are looking for?
Craig at CAMP
72SD914
Jun 17 2016, 10:20 AM
Not sure, That may be what I need. Ive been told I need them but have have no idea what they look like.
PM sent
GaroldShaffer
Jun 17 2016, 09:42 PM
If you are installing a side shift transmission in a early car (70 - 72) for sure you will need:
Shifter
Tunnel shift rod
shift rod from firewall to trans
engine bar and the mounting brackets
I believe there is a modification that needs to be done to the shift rod exit at the firewall also. I know the early shift rod is thicker than the later ones.
bdstone914
Jun 18 2016, 04:17 AM
The side shift package i am selling you has the correct engine bar end mount brackets. The ones camp 914 offered are for a tail shift.
I still have not found a good drivers side warm air guide.
Bruce
72SD914
Jun 18 2016, 05:01 PM
QUOTE(bdstone914 @ Jun 18 2016, 03:17 AM)
Bruce
Thanks guys, Please keep looking for me.
Bruce, PM sent
72SD914
Jun 19 2016, 10:05 AM
Still in need of a drivers side warm air guide.
72SD914
Jun 20 2016, 01:49 PM
Pic of what I need. The shift rod passes under the drivers side warn air guide cover. It is bolted to the case and heat exchanger.
boxstr
Jun 21 2016, 06:26 PM
I think this is what you are looking for. PM if interested.
Craig at CAMP
72SD914
Jun 21 2016, 07:23 PM
QUOTE(boxstr @ Jun 21 2016, 05:26 PM)
Craig at CAMP
PM sent
That looks like what I need.
