Full Version: Fuel system questions
DaGreenOne
1974, 2.0 914, recently converted to dual Weber carbs from the original fuel injection system. Always use premium fuel and continue to do so.
Carbs are clean, as are jets, ports, etc. The car idle at times is very erratic, car will miss and run erratic as well. After driving across town maybe 20 to 30 miles it is very hard to start once engine has heated up, not over heated though.
I is it wise to use a lead additive, maybe use regular gas due a lower ignite temp, what installing a inline trans-dapt glass fuel filter????
I am new to this so have a lot to learn. Thank you for help you might be able to provide. My email is: Laafh@aol.com
Mark Henry
Number one for the rough running is likely a linkage/sync issue.
Hot start like you describe is often heat soak, are you using the phenolic spacers? You should be.
Additives are mostly crap, lead substitute doesn't have lead in it and actually lowers you octane rating.
You want to run premo gas, if you can get pure gas run it.
rhodyguy
Post some pictures of your current setup.
