Full Version: 901 Transmission
Splash440
Can someone direct me to the torque values for a 901 tail shifter. I know the speedo drive nut and main shaft nut are 80 ft/lbs, but do not know the others. For example, the shift fork nuts.
Any help would be greatly appreciated.
76-914
QUOTE(Splash440 @ Jun 20 2016, 10:07 AM) *
In general, 8mm bolts call for 14.7 ft/lbs, but 18-19 is OK. 10mm fasteners use about 35 ft/lbs, and 12mm use 56 or so.
