I know that there are a lot of electrical issues with the 914. My new project has an issue where the 4 fuses on the left side of the panel have no power going to them. Is this a common problem?
I don't have the fuse cover so I don't even know what these fuses feed. Headlights come up. I have one low beam light that works and marker lights work, and wipers work. and the car starts and runs. Since I am doing an engine swap I am thinking of trashing the entire harness and using an aftermarket 11 circuit harness and just re wire the entire car.
Question. Is it worth it to trace all the factory 40 year old problems out and fix them to just have something else quite the next month or just start over.
I'm fairly good at wiring and reading schematics so I can go either way if I can find legible factory diagrams to look at.
open to suggestions.
