I am trying to narrow down a tire option moving forward. I have standard tires that are fine for the road, but only give me about 1 maybe 2 laps before they overheat. I have heard some good things about the below tire options but I am having trouble narrowing it down.
The use will be as follows. I drive the car on the road, 1 maybe 2 days a week. I don't drive it in the rain, so that is not an issue. It does not do long freeway drives, mostly spirited drives to work or around town on the weekend. It is mostly becoming an AX car, and I am really wanting to step up the tire compound for that reason. I would also like the tire to be better rated for some DE/TT events in the fall.
I have 15"x5.5 rims on a narrow body that currently have a 195x65x15 on them. I am thinking 205x50x15 (which gives me more options), or 195x50x15 which leaves me with the Toyo Proxies. the longevity to stickiness ratio is somewhat of a factory in budgeting...I can't be buying 3 or 4 sets a year.
The car is mostly stock set up with a 1911cc short stroke, weber 44s and cam. Front adjustable sway bar and adjustable C/O Bilstein HD's in the rear. I think I might add a roll hope with lateral struts during the summer, not sure if that would need to be factored in.
Any feedback would be great. I have done some research but haven't found info with a car/set up relevant to mine. A.K.A a slower 914-4 narrow body.
