cal914
Jun 21 2016, 01:38 PM
I recently had our 1.7 serviced and they reset the gaps in the tappets but now the engine seems to make a rattle noise now,something it didn't do before hand they are experienced so i doubt that they set the wrong gaps but somethings changed
Thanks Brian
Rand
Jun 21 2016, 01:41 PM
Sounds like they don't know the right specs and got some way too loose. Ask them if they know what should be .06 vs .08 and if they know which 914s had engines that needed different specs.
Bob L.
Jun 21 2016, 02:15 PM
Does it quiet down after warming up?
76-914
Jun 21 2016, 02:18 PM
That or they gapped chromoly rods, unwittingly. Also, check your heat exchanger for a loose fit or some tool left on top of an exchanger.
cal914
Jun 21 2016, 02:29 PM
QUOTE(76-914 @ Jun 21 2016, 12:18 PM)
The noise is defiantly coming from the engine , when I spoke to the guy he said that the gaps where really tight could that mean that they are chromoly rods (what ever they are )
Thanks Brian
TheCabinetmaker
Jun 21 2016, 02:55 PM
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock
barefoot
Jun 21 2016, 03:22 PM
QUOTE(The Cabinetmaker @ Jun 21 2016, 04:55 PM)
Sodium filled push rods ???, mine are just just aluminum with open ends.
r_towle
Jun 21 2016, 03:58 PM
Doubt the push rods were replaced, just bring it back it may just need to be done again...
Mark Henry
Jun 21 2016, 04:45 PM
QUOTE(barefoot @ Jun 21 2016, 05:22 PM)
Yep.... OE 2.0 exhaust valves are sodium filled.
stugray
Jun 21 2016, 05:28 PM
He said pushrods.
the pushrods are not sodium filled but the valves are.
In fact they are hollow so they can pump oil to the rockers.
Jun 21 2016, 05:44 PM
Check the fan
TheCabinetmaker
Jun 21 2016, 07:53 PM
Stu is correct. Sodium filled valves. Not sure what I was thinking.
