Full Version: Help!
pacman
Hey guys problem here, i went to change out my speedometer drive and it is frozen into the aluminumn shaft inside the trans. I have tried everything I can to free it up with no luck. Any ideas?
Jeffs9146
PB Blaster over night then use a large pair of channel lock pliers to gently turn it back and forth. Make sure you have removed the bolt that is holding it in!!
bdstone914
QUOTE(pacman @ Jun 23 2016, 08:14 PM) *
I can sell you one of 914Rubbers new improved ones with two o-rings for $60 or a used one for $15 shipped.
Would have been easier to break that nut loos while it was still in the trans where it is held in place by the bolt.
pacman
QUOTE(bdstone914 @ Jun 23 2016, 09:54 PM) *
I appreciate the offer! Might end up taking you up on that if i cannot get it unfrozen. I tried it in the tranny but because of a stupid mistake cracked a little bit of the case around the thread so cant do that because of risk /:
pacman
QUOTE(Jeffs9146 @ Jun 23 2016, 09:44 PM) *
Is there another bolt besides the one that runs through the trans?? Thanks
-Parker
r_towle
Get a gallon of carb cleaner and dunk it for about ten minutes.
Jeffs9146
Look at the photos in this link to see the bolt that I am talking about.
Speedo Angle Drive
pacman
Thanks guys! Ended up getting it free with a shop and a little heat. Hope to throw it back together soon
