QUOTE(jrblackbox @ Jun 24 2016, 04:47 AM)
Anybody got a pair available for 4x130, will need bolts too, I have steel wheels. TIA
What wheels are you installing and why do you want to space them out?
I have not seen 1" spacers for 4 lug. You would need 50mm long bolts. Have seen them either.
You may want to go with adapters that bolt to the hubs.rotors and have studs that would use open end lug nuts.
The rears are not hub-centric and spacers or adapters will exagerate the problem.
Early front rotors are not hub-centric and lates are hub-centric.
