colingreene
Jul 11 2016, 09:39 AM
I have a straight cut cam gear, its not honestly all that loud.
Mueller
Jul 11 2016, 10:01 AM
QUOTE(colingreene @ Jul 11 2016, 08:39 AM)
thanks, I've watched a few youtube videos and with rest of the Type IV engine sound (mechanical, intake and exhaust) the cam gear doesn't seem that bad.
Makes it sound a little more /6 engine'ish
Mueller
Jul 11 2016, 09:22 PM
Still trying to find some input on whether or not the stock L-Jet will work with this 9600 RAT camshaft?
Dual Webers are calling my name, trying to avoid spending the $$$ and joining the darkside.
McMark
Jul 11 2016, 09:28 PM
Induction is easy to change. Run the L-Jet and see what happens.
Mike Bellis
Jul 11 2016, 09:32 PM
Run the L Jet and put a piggy back system or full ECU swap on it.
colingreene
Jul 11 2016, 09:42 PM
the right and best way to do modern ish fuel injection on the cheap would probably be Megasquirt.
Mueller
Jul 11 2016, 10:26 PM
QUOTE(colingreene @ Jul 11 2016, 08:42 PM)
Just nervous with a fresh rebuild, what if it doesn't start right away or stalls too often?
Will I screw up my new cam if it takes too long to get it running longer than 20 minutes or so?
colingreene
Jul 11 2016, 11:12 PM
You might want to talk to Mark on here about it, or read through some of the builds using it.
Worst case start it and run it on a carb to break the cam in.
McMark
Jul 12 2016, 06:14 AM
The cam assembly lube sticks around for awhile. And if you run closed loop and autotune you can get it to rev to 2000-3000 pretty easily and be sure you're not flooding the motor.
With no load on the engine, your mixture and timing isn't nearly as critical. So you run the engine, rev it up, keep an eye on the mixture, but keep it running/rev'd until the cam break in is over. Then move your attention to tuning.
Also, this is the part where I praise the gospel of dyno tuning. Pay the money. Get it done first, not last. It's worth every penny.
jim_hoyland
Aug 11 2016, 12:22 PM
Any updates Mike ? I am looking at upgrading my L-Jet as well. Currently, it has the 94mm pistors and 2L crank shaft. I have a set of stock heads that are resurfaced and and new valves added- no mods though.
My local indy is going to replace the heads and suggested adding 96mm pistons. Since you drove my car at the WCR 2015 at San Simeon, I thought you might have some useful suggestions. And. it hasn't pinged again...
Gonna stay L-Jet
Mueller
Oct 18 2016, 09:08 AM
Finally getting back to my engine.
I picked up new lifters and uncut chromoly push rods from The Type IV Store,
I'm thinking I should go with better than stock valve springs for my 9600 RAT camshaft?
Mueller
Oct 26 2016, 11:08 AM
Bump for spring recommendations!
Also, any work I can do myself on the combustion chambers like adding a radius to the edge from the flat to the combustion pocket?
Mueller
Mar 7 2017, 01:55 PM
Let's see if this one gets ignored as well
Can the stock Type IV oil pump deal with a remote cooler all the way up front behind the bumper if i wanted to go with a GT type setup?
Mark Henry
Mar 7 2017, 01:56 PM
QUOTE(Mueller @ Mar 7 2017, 02:55 PM)
no
Mueller
Jun 7 2017, 07:03 PM
Time to start working on the engine again.....
Dual or single valve springs? (Raby 9600 cam)
VaccaRabite
Jun 8 2017, 07:06 AM
QUOTE(Mueller @ Jun 7 2017, 09:03 PM)
I think that HD springs were used on most the Raby cams with a more aggressive ramp.
The springs that came with mine were single coil, HD springs.
Be 100% positive that you use the right lifters for your new cam. Ceramic lifters are best, or the correct Raby / LE lifters for that cam. Otherwise you can flat spot the cam in no time flat. Learned that the hard way. :-(
Zach
McMark
Jun 8 2017, 07:23 AM
I think that cam would prefer to have dual or HD springs. But if you email the Type4Store they should be able to tell you what's recommended.
Mueller
Jun 9 2017, 12:43 PM
QUOTE(McMark @ Jun 8 2017, 06:23 AM)
Called and got someone that had the cam card!
Recommended dual (with a little hesitation which makes me nervous?)
Specs:
.335 IN
.400 EX
Duration 290°
@ .050" 252° IN
@ .050" 254° EX
Looking at the Web Cam catalog, it looks similar to the 86a (below) except for intake lift, I hope it was a misprint or I didn't hear her correctly. Web Cam doesn't show any cams with
that small of an intake lift!
.435/.435 290°/290° 252°/252° 86a N/A N/A
00-232
Strong mid and upper end performance for high performance street engines. WEB CAM mechanical lifters required. Requires
Performance Valve Spring Kit, and New Lifters Part #00-265.
I think I will measure the lift just to make sure.
Mueller
Jun 9 2017, 12:45 PM
QUOTE(Vacca Rabite @ Jun 8 2017, 06:06 AM)
Zach
I have the parkerized lifters from the Type IV store.
Mueller
Aug 11 2017, 12:02 AM
I just did a quick measurement using my HF digital calipers.
Lift for stock cam:
I = .277 , E = .255 so the intake lift is .022 greater than exhaust.
9600 cam:
I = .310 , E = .384 so the exhaust is almost .070" greater than the intake? Turbo cam or okay for N/A?
McMark
Aug 11 2017, 08:41 AM
More exhaust flow to compensate for the type 4s poor exhaust flow characteristics. Common idea with a variety of implementations.
Mueller
Aug 11 2017, 11:29 AM
QUOTE(McMark @ Aug 11 2017, 07:41 AM)
Thanks, that is what I was thinking, will run it.
Keith914
Aug 11 2017, 11:59 AM
Back to your original question, I suggest you evaluate upgrading your oil pump (higher flow) in tandem with Tangerine's oil pressure relief valve upgrade.
Mueller
Aug 15 2017, 12:43 AM
QUOTE(Keith914 @ Aug 11 2017, 10:59 AM)
Thanks, ordered the Tangerine Racing oil pressure relief spring upgrade.
Only oil pumps i could find are the 30mm units:
https://type4store.com/products/oiling-syst...hicles-486.htmlI also found an article for using the stock oil pump and making it better than as delivered:
http://www.shoptalkforums.com/viewtopic.php?f=1&t=127097
McMark
Aug 15 2017, 07:04 AM
Did you want a 26mm pump? I can send one your way.
Mueller
Oct 14 2017, 08:20 PM
Started to clean the engine again to get it ready to put back together.
I Bought a media blaster kit to hook up to my pressure washer....
I am using baking soda for the media.... 1st test and it works pretty darn good, just messy (more so the water spraying back at me ) I'll have to fix that!
There was a lot more build up between the webs before I gave it a blast. Just plain water out of the gun didn't do squat.
Mueller
Nov 7 2017, 12:15 PM
Megasquirt question...really EDIS related. Older MS2 V3.57
I screwed up and bought the wrong EDIS setup, I bought the -8 version instead of the -4 version.
I still think I can get it to work correctly as long as I mount the sensor 50° as per EDIS-
8 requirements.
The stock V8 firing order is 1-3-7-2-6-5-4-8 (wasted spark pairs are 1-6, 3-5, 7-4 and 2-8)
As long as I connect to the correct coil I see no reason it wouldn't work.
Any possible damage if I didn't hook up the other 4 spark plug wires?
Will I damage a coil if it is only firing on one side and not as a pair?
Good time to convert the heads to dual plug?
Nov 7 2017, 05:59 PM
That's definitely above my pay grade.
McMark
Nov 7 2017, 10:24 PM
I'm pretty sure you can just set up your MegaSquirt board with a second ignition driver and then dispense with the EDIS altogether. Less components to break/die. Simpler wiring. Simplicity.
Mueller
Nov 7 2017, 11:58 PM
QUOTE(McMark @ Nov 7 2017, 08:24 PM)
Thanks I'll look unto that. Didn't really want to go with COPs.
JamesM
Nov 8 2017, 12:54 AM
QUOTE(Mueller @ Nov 7 2017, 10:58 PM)
If you want the "easy button" for spark output look at VAG Part #032905106B wasted spark coil off late 90s/early 2000s VWs. Aftermarket/generic can be had for less than 20 bucks. Its logic level so no high current ignition drivers are needed, the wiring of it is crazy simple. Only thing you need to know is to swap the 3 and 4 plug wires from how they are labeled on the coil to account for the Type 4 firing order.
McMark
Nov 8 2017, 10:49 AM
QUOTE(Mueller @ Nov 8 2017, 12:58 AM)
You've already put more work into EDIS than it would take to add a second driver -- and there's more work to make the EDIS function. Follow James recommended coil and you'll be done with ignition. With what's available now, I don't see why anyone should ever use EDIS.
Mueller
Nov 8 2017, 11:49 AM
Thanks Mark and James.
So i do not need to upgrade to the BIP737 ignition drivers with that VW modual?
Dr Evil
Nov 9 2017, 12:27 PM
I may have an EDIS4 if you want it.
Mueller
Nov 9 2017, 12:58 PM
QUOTE(Dr Evil @ Nov 9 2017, 10:27 AM)
Thanks, I ended up buying the VW unit above. $20 shipped brand new on Amazon, that route seems to be better method now.
Mueller
Nov 15 2017, 01:28 PM
Silly question, I need to buy or make an engine stand yoke/holder for my Type IV, if I make one does it matter which half of the case I mount to the engine stand to start the assembly?
914work
Nov 15 2017, 07:18 PM
Perhaps these might help?
McMark
Nov 16 2017, 08:01 AM
I haven't worked with a MegaSquirt unit yet, so I haven't done a bunch of research on the nuance of adding ignition drivers. But with that coil you're only using a few milliamps to fire the coil, so you don't need beefy drivers. Essentially, any driver will work fine becuase the draw will be far below the safe rating. The BIP737 is something like 11A max. So that VW coil will be about 1% of that.
I always install the stand/yoke on the 3-4 (passenger) side of the engine case.
Mikedrevguy
Nov 16 2017, 08:29 AM
Look forward to seeing this all come together. Good read. Thanks.
Mueller
Dec 25 2017, 02:14 PM
Finally, some work related to my 914...
Removed the main cylinder studs this morning.
Noticed one of the smaller studs is bent pretty good. Will have to source another one.
I plan to clean the engine case one more time, might be a little easier with the studs removed. The other side has a lot more oil caked onto it for some reason.
Click to view attachmentClick to view attachment
Mueller
Dec 28 2017, 07:54 PM
Cleaned my engine, also deburred it a little bit also by cleaning up the extra aluminum from the casting process. Not as sharp now.
Cleaned it using my pressure washer with media blaster attachment with baking soda.
Click to view attachmentClick to view attachmentClick to view attachment
Mueller
Jan 11 2018, 09:51 AM
In case it is not in Raby's Type IV assembly DVD I have not fully watched,
What do people use and recommend for installing the head/cylinder studs?
Mueller
Jan 12 2018, 02:47 PM
Bump for:
What sealant do people use and recommend for installing the head/cylinder studs?
76-914
Jan 12 2018, 03:57 PM
Mike, it's in there somewhere but IIRC it was Loctite PST 565 thread sealant.
Mueller
Jan 12 2018, 04:21 PM
QUOTE(76-914 @ Jan 12 2018, 01:57 PM)
Thanks, I'll have to finish watching it this weekend.
holtby914
Jan 12 2018, 06:31 PM
Did you order the DVD recently? I'd love to get a copy.
Mueller
Jan 13 2018, 11:39 AM
QUOTE(holtby914 @ Jan 12 2018, 04:31 PM)
Actually I asked about it and a few weeks later someone sent me their old one anonymously.
I'd put a WTB in the classifieds.
https://vwparts.aircooled.net/Bug-Me-Video-...build-vol-8.htm
Mueller
Jan 21 2018, 02:32 PM
Not sure if this qualifies for being cheap or resourceful. Lost a dowel pin and had a perfect sized HSS drill that I figured could be used. Drill still usable so no big deal.
Anyone using special engine break-in oil?
https://type4store.com/products/sealants/jo...-12-quarts.htmlClick to view attachmentClick to view attachment Click to view attachment
McMark
Jan 22 2018, 07:57 AM
Lookin' good!
Mueller
Jan 27 2018, 11:03 PM
Dominic was nice enough to send me a straight engine stud and I got my 1.7 rockers with 911 adjusters.
