A problem has recenly developed and I can't figure it out. The car starts up easy and on the first crank. I let it warm up a few minutes and drive....It drives fine as it's warming up.
Then after about 15 or 20 minutes the engine starts developing a shudder. Idles fine but and can run ok under low load but under some load the #4 cylinder starts popping and firing up through the carb. feels like it's running 3 cylinders and wasting gas.
It's been suggested I do a compression test but I'm thinking if the engine runs great cold and while warmin up; the compression should be ok.
Is there a case where comprression is ok when cold but low when hot? Can't figure out why car runs great when starts f'n up.
1.7 with dual weber 40 IDFs
