Hi All -
I am in the process of restoring my 914's pedal assembly. After getting it out of the car, whacking out the pin that helps the clutch pedal clutch the clutch shaft, and getting the clutch pedal off, I went to work removing corrosion from the 13mm nut that holds the clutch shaft to the pedal assembly base plate, only to discover that someone had welded everything together. Sadly, it seems the only way these pieces are coming apart is with a grinder, at which point they are not going to be easily salvageable. (Especially since I don't have a welder.)
Thus, I would like to buy:
1.) A replacement pedal assembly base plate -
2.) Clutch shaft -
Does any body here have these items, which they are willing to part with?
Thanks in advance -
Charlie
