Looking for a bit of help please.
I had no TPS signal when testing using the correct 1.7 adjustment sequence with an ohm meter.
Sucessfully installed a new board .
Still no signal when testing & doing set up adjustment.
even when working through simulated accel and decel when internal contacts change.
The meter works . (tested other known components)
Tested the connection from "pick up" to board and all work so I know I am making board to contact on all fixed and movable connections is good.
I am thinking that the other part of my TPS is bad ...Cleaned contacts.
I posted a photo (photo not mine but arrows to area of concern.
Any help or is it time for a "new" TPS.
Porsche # 022 906 111 B
Bosch # 0 280 120 021
