Which is the best way to install your tight rear sway bar bushings ?
1.Heat 'em up or cool them down?
2.Also do you press them in the drop-link first, THEN press in the rear sway bar ball end or visa-versa ?
3.AND do you lube the bushing cup with ? bearing grease or... ?
