QUOTE(A&P Mech @ Jul 8 2016, 11:21 PM)
Thanks for the heads up. I do have an electric impact. I will give it a shot tomorrow. Did you find a torque spec for the nuts?
I'm assuming your kit also came with the all-metal "Stover" prevailing torque lock nut (it has a conical top and chamfered corners). The threads at the top (conical or crimped end) of the nut are distorted to keep the nut from loosening.
The Haynes 914 manual says that the nuts on the top of the outer tie rod ends are torqued to 33 ft-lbs. The folks at Pelican (where I bought the Lemforder kit) said to torque the locking nuts to the same value.
FWIW, all of our old Volvos use the Stover-type nuts on the outer tie rod ends. No problems in any of five 240s in over 30+ years.
