cal914
Jul 10 2016, 12:32 PM
When putting my 1970 914 into gear lately i'm having to push the clutch almost through the floor ,what could be causing this its only be happening the last couple of trips
Thanks Brian
era vulgaris
Jul 10 2016, 01:00 PM
It's probably that your clutch cable is stretching, or the adjuster nut has come loose.
Easy fix. Tighten the adjuster nut a few turns, and then see how it feels. Make sure you have a jam nut on there too.
Jeffs9146
Jul 10 2016, 01:24 PM
Check your clutch cable tube at the firewall!
rgalla9146
Jul 10 2016, 04:08 PM
and in the tunnel
rgalla9146
Jul 10 2016, 04:37 PM
[quote name='Jeffs9146' post='2369805' date='Jul 10 2016, 03:24 PM']
[/quote
Double
