QUOTE(Amphicar770 @ Jul 12 2016, 09:42 AM)
Thanks. I assume that the center gauges share a ground as they connect through common harness. Where does that brown ground wire terminate at the vehicle body?
I don't know where the brown ground wire attaches to the chassis. Follow the brown wire from the center console to it's termination on the chassis.
You can always measure the voltage on both voltmeter wires by measuring the both wires to chassis. Connect one side of your multimeter to chassis and check the voltages on the back of the center console voltmeter. The brown wire should read 0V and the other wire somewhere around 12-14V.
