DblDog
Apr 9 2005, 07:33 PM
OK...the piece of rubber trim between the rear window and the engine lid...is there something I'm missing...its seems like it should just push on, which I did but it won't stay put. Also the window is in place and I don't really want to remove it...help! Thankx
TravisNeff
Apr 9 2005, 08:28 PM
keep pushing it in - it will go and you don't need to remove your window. A pair of pliers may help get it seated. Good luck!
914GT
Apr 9 2005, 10:36 PM
If you have the repro rubber piece it does not seem to grip the edge well. You can run a small bead of 3M weatherstrip adhesive into the seal and push it on and that will help hold it in place.
