Aaron Cox
Apr 9 2005, 09:28 PM
had car 4 wheel aligned six months ago.....
2.5 degree neg camber is what it was at (guy didnt have shims)
looks like in the last month my left rear gained a few degrees! i havent hit anything....
no accidents...
no spins.....
bolts are tight....
WTF happened????
Joe Bob
Apr 9 2005, 09:33 PM
Welllllllll....the suspension ear is like, hollow., ya know?....and can take on water inside the two pieces....and once weakened..... tweak...typically the passenger side has the issue due to an addition of battery acid....but the driver side having the problem is not unheard of....but less common.
Time to get underneath and check for bends in the rear suspension, Joe Bob
Aaron Cox
Apr 9 2005, 09:39 PM
and brand new rear suspension bushings..... ( 8 months old)
Andyrew
Apr 9 2005, 09:42 PM
Only you can answer that question!
You know what everyone is going to say... lol
Drive it around the block.. park it different.. recheck.
Still the same... then you know what to do....
Aaron Cox
Apr 9 2005, 09:44 PM
blah.....
ill have to take a look soon....BUT I HAVE NO effin time
fudge.....
J P Stein
Apr 10 2005, 01:37 AM
That's whatcha get for drivin' around on the bump stops
Seriously, to get more negative camber, the inner ear would have to grow longer. Look elsewhere...like the trailing arm (see bumpstops above).
