If your car has the dreaded single carb "upgrade" this is everything you need to get back to original.
This system will work on any non 2.0 but is specific to 1974, 75 have the same system but with some minor differences.
Air box and mounting bracket
Fuel pump and Y tube
Clean harness with all sensors and injectors attached
Correct distributor in like new cond
ECU and mounting bracket.
It's all there see pic clean and in good working order.
This came off my 74 Sunflower yellow build challenge car and ran perfectly when removed. $950 offers
