So every time I try add brake fluid it slowly leaks at the master cylinder at the reservoir inlet. It's just the front one from what I can tell. I've pulled the tube and seal out. Seal looks newer. Master cylinder looks new. I'm guessing maybe the seal was installed incorrectly? Can anyone help me out with an explanation on how those seals are supposed to be installed? Tried searching around but haven't found anything.
Maybe this picture helps? This is what I'm dealing with.
Thanks, Scott
