My 76 2.0, 118,000 miles, has always had it's original smog equipment and always passed CA smog so far. I have read many tips in here to help CA '76ers to pass smog, but wanted to show you my current specifics and test readings so maybe a smog expert member can tell me anything else to do so it continues to pass. The last smog station data is shown below, and the previous test smog numbers were almost identical to these readings. The engine had dropped a valve seat about 1800 miles prior to this most recent test. The heads were removed and the valve seat repaired. The engine must have had a valve adjustment done then, but not since. I recently changed oil to Brad Penn 20/50 (The car doesn't smoke on deceleration since then!). I also had a Crane Fireball XR700 electronic ignition installed a long time ago and the engine has never missed since then. I have recently switched fuel to 87 octane from premium, no problem. Looking at the smog test readings below from the last smog test, can anyone offer ideas for any other things to do before I have my next smog test soon?
Click to view attachmentClick to view attachment
