QUOTE(carcus @ Aug 1 2016, 01:02 PM)
I have a new fuel pump and filter on the way. This is a FI 76. The manual I have only talks about the carb version and says it is near the fuel tank. Where is the location of the fuel pump on the FI 75-76 models? Any pictures or install or tips would be appreciated. Thanks allQQQ
Open your trunk and look on the back wall where the gas tank is and there is a cover on the right lower edge. remove the cover and the pump will be attached. The filter may be right there or you may have to remove the front lower stearing cover and look in the round hole on the passenger side. If you still cant find the filter you can remove the tank or look in the engine compartment.
