QUOTE(Rob-O @ Aug 2 2016, 03:05 PM)
Just to confirm a few things. The injectors aren't pulsing? Or they may be pulsing but the car won't start because it's not getting fuel? Because those two issues have different routes to check.
If you have a chance, pull a fuel hose and turn it over (be safe around ignition sources!!!). I would choose the return line just before it leaves the engine bay. That way if you are getting fuel, you're safe in assuming that fuel is making it past all the injectors and the cold start valve and heading back to the gas tank.
If the fuel pump is working you should get a decent stream of fuel coming out of that hose when the ignition switch is turned on.
Next the dual relay comes into play. The fuel pump is controlled by the dual relay. You said you read up on L-Jet, so I'm sure you understand that the fuel pump turns on with the ignition switch 'start' key position on the dash, but then control and continued operation of the pump comes from the AFM. If the flap on the AFM has moved past it's resting position, the ECU and dual relay understand that to mean that the engine is getting air, and keeps the fuel pump running. If you have a helper you can check that too. You can manually move that flap and listen for the fuel pump running.
If the pump is pushing out fuel while the ignition is turned on AND the AFM has moved past it's resting position, then you've got fuel running through the fuel line loop, it just isn't coming out of the injectors. If that's the case, then the problem is most likely the resistor pack. You can use a stethoscope to listen to the injectors firing. Or if you don't have a stethoscope, put your ear on the plastic end of a long screwdriver and the other end on the metal body of the injector (Clay Perrine checked mine that way!).
If the resistor pack checks out we can move on to checking continuity, but between continuity and checking resistance values or components, I don't think you really need to pull the whole harness out. You should be able to check the continuity and resistance with the components in the car. But we'll get to that later.
Thanks for the help. I had a few minutes to test. This is where I'm at:
Fuel delivery confirmed
at supply and at return. Confirmed delivery with yellow wire on Post II of regulator plate.
Swapped resistor pack. Tested. Same result. No fuel from injectors.
Swapped dual relay with a crusty one. Same result. No fuel from injectors.
Some additional info:
New 7MM fuel lines. As mentioned, recently serviced injectors' are: Bosch 022906031c
I have only been testing cylinder 3 and 4 injectors. I can test 1 and 2 injectors to see if it's a systemic problem.
I'll move on to the stethoscope test. And get a helper to test AFM. I also have another AFM I can try.
Appreciate all the help! Will keep you posted.
