QUOTE(amfab @ Aug 3 2016, 03:58 PM)
I am about to redo my dash face. I know I have to remove the steering column.
Is there a way to take the upper column off (or just lower it) keeping the wheel and ignition/wiper/turn signal module all together?
Or do I need to pull each piece then unbolt it?
TIA,
-Andrew
You can pull the 3 wiring plugs. (ignition switch, wiper and indicators) as said before they are all different so you cant easily mix them up.
The hardest job is the washer tubes if they are short, they'll need to come off. If they are long, then they can stay on if you support the column when its pulled forwards (much easier to take them off really)
1 x M8 nut and bolt on the universal joint to remove, and two column bolts seen looking up through the slotted holes in the knee pad and the upper column should pull out.
Good luck
PS the washer tubes are tight on the washer valve and the plastic breaks easy while the tubes perish and leak. It's a good time to put new washer hose on the car if you've still got the original fitted. Hose is only a couple of $ per metre
