DavidSweden
Aug 4 2016, 03:44 PM
Looking for some advice, the engine lid on the passenger side has a large gap but it looks ok on the drivers side any ideas why?
Thanks
Chris914n6
Aug 4 2016, 03:57 PM
Shrinkage from the cold
Actually it's just out of alignment. Should be consistent with all the other gaps on the car.
toolguy
Aug 4 2016, 04:01 PM
Also look like it's a little low on the right side by the window glass. . better
check the hinge bracket on the firewall for cracks. .this is what happens when the hinge angle bracket cracks at the curvature. . also adjustable side to side by loosening the hinge bolts and slide it to the right. .
You're missing the rear window to engine deck lid seal also. .
EdwardBlume
Aug 4 2016, 04:28 PM
As noted its off on both sides.
Looks like you need a window seal...
worn
Aug 4 2016, 06:26 PM
QUOTE(RobW @ Aug 4 2016, 02:28 PM)
Also, it's supposed be flat black underneath.
76-914
Aug 4 2016, 10:12 PM
IIRC there is some black edge trim for the lid.
bretth
Aug 4 2016, 10:42 PM
Your sticker reminded me that I actually heard a Ziebart commercial on the radio today. I thought they were a company gone many years past.
Brett
DavidSweden
Aug 5 2016, 10:29 AM
I had a look at it today and i dont see how the lid can be adjusted from side to side.
Whats the procedure?
Thanks
matthepcat
Aug 5 2016, 11:14 AM
I had the same thing on a previous 914. I had to weld in new mounts from restoration design. One side was cracked and failing.
