Pretty sure that my struts are shot as the front suspension is making horrible noises around the shock area and everything is tight per spec. But if its not the shocks then I want Koni yellows in the front anyways (Koni reds in there now)
What I dont know is if I Have Boge or Koni struts. Bolt spacing on the caliper is 3.5mm Struts are from I believe a mid 70's 911. Can anyone determine what I have? I cant really tell based on the research I have done.
Thanks!
