in the pass side shot it appears that the tie rod outer end is angled up a bit. the drivers side "looks" like it's fairly close to being parallel to the horison. the rod and arm "look" close. save up the coin for the corner balanceand alignment. your weight will (should) be factored in. how does the whole backspacing, offset compare with your rims and 4 lug fuch? low slung looks cool, i mean on cars joe
. my car was raised a bit, even with a bump steer kit installed, to achieve the angularity the tech and i talked about. use of car played a big part. i run 205/50 tires. they make my car look higher than it is, but they fit in the wheelwells nicely and 0 rub. your car looks tall in the ass. how does it corner. if you approach a set of rail road tracks perpendicular, does the sterring wheel dance when you cross the rails?
k
