NoEcm
Aug 7 2016, 05:23 PM
I have a leaking pressure switch on the master cylinder and I need to purchase a single pole one for a '75.
Is this part available separately?
JeffBowlsby
Aug 7 2016, 05:46 PM
The single pole switch grounds through the switch case, where the two pole requires a separate ground wire to the chassis if you need to use it.
914Sixer
Aug 7 2016, 06:06 PM
I should have a NOS one if you want it. Can check later today. $18 shipped.
NoEcm
Aug 7 2016, 06:41 PM
QUOTE(914Sixer @ Aug 7 2016, 05:06 PM)
If you have a single pole master cylinder switch I'll take it.
NoEcm
Aug 26 2016, 06:26 PM
I purchased a new switch and now for the installation.
From the drawings I see that there is an O-Ring between the switch and master cylinder. I also see that the O-Ring is NLA.
Is this just a common O-Ring that I can purchase at a hardware store?
