It is currently a non-numbers matching LE since the case was apparently messed up beyond repair when it spun a rod bearing a few years ago. I think Jake still has the case, however. Now powered by a Raby 2056 built from a 1.8 case.
The next phase of restoration is rust repair along with correcting an old front panel repair. Not sure I will ever be able to get this done due to time and cost to have it repaired correctly - pretty much a full restoration of the body.
Enter the RPM Supercharged / GT-flared / 5-lug Fuchs 914
This car is beautiful and has a lot of cool features. Though built on a '75 chassis, many parts from a real -6 were used on this build - ignition switch, steering column, suspension, etc I won't say no rust but at least no rot. Don't get me wrong... the car needs a little TLC to get it just right but it is a solid base. And, yes, it does run!
I have a chance at purchasing this car. Of course, I would need to sell my LE first.
What would you do in my situation? Sell the LE and buy the S/C? or keep the LE?
I have always liked the LE cars. Had a Bumble Bee "back in the day". I love my Creamsicle - a lot of work has gone into it to get it to where it is today. And it is kinda cool owning a factory limited production car.
But... the S/C 914 is suh-weet!
If I did sell the LE, I would most likely pull the Raby and replace with a good running stock 2.0 w/FI.
I'd then drop the S/C engine and store it while running the Raby. To me, the S/C engine is an interesting bit of history, but what I really like is the overall look/build of the 914 itself.
Just looking for what others may think. Some rhetorical questions: If I sold the LE, would I be kicking myself in future years as the value goes up more than a one-off? Or do the -6 bits, steel GT flares, etc offset that? Do I even care about the future value?
I love driving my 914 so maybe the better question is... of the two, which is going to handle/drive better? The LE with 21mm torsion bars, 140# springs, stock (at the moment) shocks, front sway bar, and Mahle rims with 205/50 tires? Or the 914-6 suspension with 6" & 7" 5-bolt Fuchs under a flared body? (not sure what torsion bars/springs/shocks/sways are on that car).
Thanks!
