porschetub
Aug 13 2016, 12:39 AM
Was thinking of going to these for shock tower mounts and front sway bar bushes.
Know little about them so need info,have heard about noise issues but the fact they are less compliant than rubber should help?
Yes I have more research underway,just floating the idea @ present,thanks
ConeDodger
Aug 13 2016, 01:46 AM
What do you hope to accomplish?
Poly bushings tend to give you a harsh ride. No big deal in a purpose built car intended to corner like a carving knife but if you want your wife or girlfriend to actually ride in the car?
The only bushings I have found to give a great ride and precise cornering are Elephant Bushings or needle bearing bushings if you can find a set.
Cairo94507
Aug 13 2016, 05:53 AM
I have had the hard poly-bushings in other cars and they made noise most of the time despite being properly lubed.
For my Six I went with Elephant Racing rubber bushings as they are one step better than the OEM rubber, but are still rubber. Of course, I have not driven the car to check out their actual performance - but they come highly recommended. MY goal is a good, comfortable, decent handling, street car.
76-914
Aug 13 2016, 07:40 AM
On my to do list:
Remove the urethane bushings, throw them in the trash and replace w/ Elephant Racing set up.
Mike Bellis
Aug 13 2016, 09:20 AM
I don't mind the ride on mine. What bugs me is the noise. Especially if I come out of a driveway off camber, for the next few miles or days it will squeak really bad. Loud squeak, squeak, squeak, squeak. Every bump. Squeak, squeak, squeak. Not a high pitched squeak. A low pitched creaking squeak, squeak, squeak squeak... Almost sounds like the car is breaking in two pieces. Squeak, squeak, squeak....
whitetwinturbo
Aug 13 2016, 09:28 AM
There are lubricant solutions to the uro-squeak
but the ride will still be harsher than stock.
porschetub
Aug 13 2016, 09:22 PM
Squeak,squeak,squeak......got it thanks guys ,everthing I have read is true
ER will be on my list for these,Chuck has been great to deal with in the past.
ThePaintedMan
Aug 13 2016, 10:29 PM
Weird. I used Eric's bushings available at PMB, followed the instructions, but 10000 miles on them and 10 hours of track abuse on them, and they never squeaked.
boxsterfan
Aug 13 2016, 11:15 PM
QUOTE(ThePaintedMan @ Aug 13 2016, 09:29 PM)
You must be doing it wrong then. LOL
ClayPerrine
Aug 14 2016, 01:24 PM
I took out the urethane bushings on Betty's car, and replaced them with a set of Elephant bushings on both the front and rear. The car used to pop and squeak, now it rides nice. No real noticeable change in handling either. Maybe if you were trying to wring the last tenth out of the car on the AX course they would be better. But for street use the Elephant bushings are, IMHO, the way to go.
I have to do the rears on my car. I took out McMark's needle bearings and put in the Elephant bushings. There are lots of roads here that are a bit rough, and the needle bearings were beating the hell out of me. I kept them for the future, maybe I will put them in a track car someday.
Remember this is my $.02. YMMV.
tradisrad
Aug 14 2016, 01:51 PM
I love my Elephant poly bronze bushings. It was hard to part with the $$ for them, but I think they are worth it. They really do provide a smooth ride.
jack20
Aug 14 2016, 06:21 PM
I installed Elephant rubber bushings up front and Elephant PolyBronze in the rear trailing arms. I tried the poly bushings first. Big mistake. Had to take them out and do it all over again with the PolyBronze. Couldn't stand the noise.
I couldn't ask for a better balance of ride vs handling. The car is just a pleasure to drive.
Jack
JmuRiz
Aug 14 2016, 07:01 PM
QUOTE(76-914 @ Aug 13 2016, 05:40 AM)
On my to do list:
Same here, installed urethane many moons ago, when the /6 goes in, so does a set of elephant rubber bushings
Cracker
Aug 15 2016, 09:36 AM
If you are not tracking stick with stock bushings...done, quiet and easy. If you are tracking...skip to poly bronze or equivalent.
Tony
jmitro
Aug 15 2016, 01:03 PM
QUOTE(Reverend Troublemaker @ Aug 15 2016, 10:36 AM)
I thought stock bushings were NLA (edit....unless you mean the Elephant Racing rubber bushings)
rhodyguy
Aug 15 2016, 01:22 PM
The elephant poly bronze are just a tad more expensive than the rubber replacement ones they offer. For the money, I'd go (went) poly.
Andyrew
Aug 15 2016, 01:53 PM
Love love love my needle bearings.
rhodyguy
Aug 15 2016, 01:55 PM
The sets Mike made?
Andyrew
Aug 15 2016, 01:59 PM
That be the one's. Mike actually installed mine for me
rhodyguy
Aug 15 2016, 02:16 PM
Nice. The 4 lug hubs for vented rotors were works of art.
Mueller
Aug 15 2016, 02:17 PM
QUOTE(Andyrew @ Aug 15 2016, 12:59 PM)
I haven't looked to see what condition or what type of bushing I have on my latest 914 yet....that being said if I do change them I think I'd pony up the $ for Chucks poly setup. I still have extra bearings and races left over from that venture but I'll probably sell them to someone that wants spare parts.
Andyrew
Aug 15 2016, 02:26 PM
QUOTE(Mueller @ Aug 15 2016, 01:17 PM)
Let me know if you do sell. Id like to have spare parts
Cracker
Aug 15 2016, 02:36 PM
Personally, I recommend Rebel Racing's bushings...if you can get past the sporadic communication. Some of the few truly tested around a corner at 160+ mph...and driven comfortably on the street, in a teener.
Tony
