tornik550
Aug 13 2016, 03:13 PM
As the title says- what is the largest tire that I can put on 7 X 16 Fuchs that will fit on a narrow body WITH rolled fenders?
boxstr
Aug 13 2016, 03:41 PM
I had 205x45x16 Dunlops on a narrow body car.
Craig at CAMP
Chris914n6
Aug 13 2016, 04:22 PM
205-215 depending on actual width, 225 with some camber. It's the offset that makes it tight.
BIGKAT_83
Aug 13 2016, 04:28 PM
I ran 215/45/16 on 7/16 Fuchs. They were a tight fit.
BiG bOgGs
Aug 13 2016, 04:42 PM
4 or 5 bolt Fuchs?
tornik550
Aug 13 2016, 05:05 PM
QUOTE(BiG bOgGs @ Aug 13 2016, 06:42 PM)
4 or 5 bolt Fuchs?
5
Mueller
Aug 13 2016, 05:37 PM
Depends how far rolled and your version of rolled or pulled out.
Spoke
Aug 13 2016, 07:35 PM
225/50/16 on 7x16 Fuchs. Needed to pull out the fender to fit.
Chris914n6
Aug 13 2016, 07:48 PM
I've got a 205/55 on a 16x7 23mm offset that tucks with room on rolled fenders. Stock camber.
I've got 2 225 tires. Ones 9" wide, the other 9 5/8".
The 9" 225 is on a Boxster 16x7 and fits with a thin spacer. 40mm offset vs 23mm Fuchs/cookie. The wide 225 would likely rub. The wide 225 is on a 16x8 11mm offset (911) and the 8" won't fit without cutting/flares.
I've got a 215/60 on a 15x7 Cookie I can try if I remember.
Measure the inner lip to frame/truck side. Both sides will be different by 1/4" or so, but it will give you as point of reference for pulling. I got carried away with the roller and maxed it out at 10 1/4" on the small side.
