sdoolin
Aug 16 2016, 04:33 PM
I am looking for every rubber seal/grommet needed in the engine bay and engine tins. I have new fuel line grommets from Tangerine. I did see engine bay seals and the large grommets for the aux heater blower downtubes on 914rubber. Looking for all the rest. I have searched the 914Rubber website but don't find all that I am looking for. Hoping to replace the grommets on the rear upright engine tin (there are 3(?)), the grommet for the OE cyl. head temp sensor, and the grommet/fitting for the OE oil pressure sensor, along with everything else I haven't specifically mentioned.
Any/all help appreciated.
TheCabinetmaker
Aug 16 2016, 05:51 PM
Oil pressure sender at vw places. Bughaus, bus depot, etc. lots of other grommets are shared too.
sdoolin
Aug 21 2016, 03:40 PM
Maybe my search skills are failing me, but I can't seem to find the grommets I'm looking for. Bus Depot has the oil pressure sender booty, but I can't find the grommet for the CHT sensor (next to #3 spark plug), nor the grommets that are in the rear tin piece for the starter and other wiring harness. Also having trouble finding an alternator cooling elbow - Pelican says NLA.
Any/all leads appreciated...
TheCabinetmaker
Aug 21 2016, 06:36 PM
Alt cooling boot with spring at bughaus.
Some grommets will have to be sourced from a hardware store. They come in different sizes for od and id.
