Hey Aaron: Really only 3 things to worry about.
1 Thread Dia.
2 Length
3 Heat Range
You have got the first two down (not by choice).
Number 3, you going to have to learn to read them, sandy brown, tan. Its is the color of the porcilen(sp). the deeper you look into the pulg the better. If they start to get to dark go to a hotter plug. NGKs as stated above the higher the number the colder the plug. NGKs are cheap, find the heat range you want to run with them, if you still fell the need to put in high doller plugs, do it after. Oh yeah, NGK makes thoes too.
Joe
