kenpolives
Apr 13 2005, 02:52 PM
I have the correct taco plate, a new red O-ring, the sender, but I need the 2 copper washers and the paper(?) inner seal that goes between the inner and outer plates. Anybody have them or know where I can get them?
Thanks
TheCabinetmaker
Apr 13 2005, 02:57 PM
What size motor? I may have some left overs from rebuild kits.
kenpolives
Apr 13 2005, 02:58 PM
Its a early 1.7 but I snagged a taco plate from a 75
Dave_Darling
Apr 13 2005, 03:22 PM
The motor size doesn't matter.
Standard M6 crush washers will work, and you can cut your own gasket out of paper gasket material. Or you can check with All The Usual Sources and get them. I've gotten all of the related parts from the Bird in the past, though you'll likely have to phone in and order from a live person rather than using the website.
--DD
