QUOTE(ejm @ Aug 20 2016, 05:47 PM)
It's just a pin that is seized in the eye on the cable. There was a clip to keep it in place. you can see the groove for it in the second pic. If you can pull the pin on the spreader piece at the other end of the cable you should be able to remove the handle with the cable so you can heat and soak the pin to loosen and remove it.
Emj, would the pin be where the left and right cables meet?
Thanks for your assistance!
