QUOTE(flyer86d @ Aug 21 2016, 08:41 AM)
Yes it has an internal regulator and can be changed without removing the engine. I did the one on my 1983 Targa years back in a shopping center parking lot with the factory tool kit. It probably is a Paris-Rhone alternator if it is the original which is pricey but there is an identical aftermarket replacement at half the price.
You have to unbolt the strap, remove the small bolts that attach the fan housing to the engine shroud, pull the fan and housing out as a unit far enough to unbolt the wires to the alternator and take out the whole lot. Carefully pop off the fan, unbolt the alternator from the housing. As the manual says, installation is simply the reverse of the removal!
Charlie
have it rebuilt $100-120
Check the mag fan housing for cracks. If it's cracked, or the fan is damaged, send it to Ben/ MB911 for repair.
