QUOTE(Philip W. @ Aug 25 2016, 06:34 AM)
I looked over the other threads on this - it seems if we cut thoseplastic clips I should be able to remove the windshield with out bending the trim. I was very specific about this with my paint/body shop. I guess the worst is if the trim gets bent I can install the rubber seal from 914 rubber .
I'd like to keep it original as I can. That's why im not painting the front or rear trunks- they are still in original color and in good shape.
anyway - most agree- cut clips, take metal trim off safely, remove windshield then replace with new clips.
Phil I wish you luck with this and have been following your resto with interest.
My car is critically (in my estimation) an 8 out of 10,my windscreen trim is not even close,the OP had a new screen fitted and the glass monkey tore out the trim like he had new stuff to replace it with...
The trim wasn't fitted when I got the car but atleast I had a quality screen refitted
,the trim was bent so much the anodizing had cracks in it,3 hrs later it fitted just ok and no better,I have to suck that up cause it is to costly for me to import better trim.
Take it slowly and hopefully someone hasn't glued it in,it is very soft and easily bent.
