brant
Aug 22 2016, 10:36 AM
I'm trying to find grommets for another application
The open one is a good feeling t but I'm trying to use it as a plug in my engine shroud where stock 911 mfi injectors go. So ideally looking for a plug without a hole
I can't read the part numbers in this spare parts bin grommet next to it
I think it might be a 4cylinder accelerator grommet
Is that what it is?
Anyone know where I can buy 6 of them?
TheCabinetmaker
Aug 22 2016, 10:56 AM
I've seen a couple of those on fours. One on the engine shelf for oil temp wire and one on the rear vertical tin for the starter harness.
TheCabinetmaker
Aug 22 2016, 11:29 AM
914Sixer
Aug 22 2016, 11:56 AM
Going to be a VW part number . Look at Bus engine tin rubber.
rhodyguy
Aug 22 2016, 11:57 AM
Blind grommet looks like the ticket.
Mikey914
Aug 22 2016, 01:33 PM
Letme know if you can't find em.
TheCabinetmaker
Aug 22 2016, 02:40 PM
You should make every grommet on the car mark.
brant
Aug 22 2016, 03:44 PM
you guys are amazing..
the blind grommet looks like that is it!
Mark,
I can send you a PM, but I didn't see that grommet on your site?
it looks like the clark rubber ones come in 32mm or 38mm
unfortunately I need a 36mm (could probably get by with a 35mm)
Mark, what do you have in mind? anything close to 36mm?
brant
TheCabinetmaker
Aug 22 2016, 04:07 PM
Google metric blind rubber grommets. Lots of hits.
brant
Aug 22 2016, 05:41 PM
I found a few. Australia. Great British . And Chinese
I'm be got a Chinese sample coming to see
Fingers crossed
rhodyguy
Aug 22 2016, 06:23 PM
Does it have to be metric? 1.41". Do they have one for a 1 1/2" hole?
914Sixer
Aug 22 2016, 07:07 PM
VW 021 119 569A German Supply has them for $5.83
