Mueller
Apr 14 2005, 11:19 AM
any particular sizing or things to look for in a wastegate?
I do know that cockpit adjustable units should be avoided to prevent the urge to crank up the boost "just one more psi, what can it hurt???" LOL
the turbo that I don't have for the project I don't plan on attempting, has no internal wastegate
tat2dphreak
Apr 14 2005, 01:07 PM
you're more determined than me to never drive your car and make it an eternal project aren't you?!?!
Mueller
May 9 2005, 11:46 AM
the UPS driver just dropped off some packages
brand new wastegate....nice looking piece of aluminum and cast stainless steel
lapuwali
May 9 2005, 12:11 PM
Are you planning on turbo'ing this long-stroke big engine, or something smaller?
Aaron Cox
May 9 2005, 12:54 PM
are you going to use the turbo oil pump mike?
Mueller
May 9 2005, 01:10 PM
QUOTE |
Are you planning on turbo'ing this long-stroke big engine, or something smaller? |
1st will be the short stroke engine (69mm???) (internally stock 1.8)
...depending on how I like a turbo 914 will be a factor in whether or not I also turbo my 78 stroke motor.....
according to Jake, the cam I have picked out will work fine with a low boost turbo application....I went with 94mm Nickies so those will help with the cooling, but I will still be limited to boost due to the sealing issues....
QUOTE |
Wow, I never see anything that shiny at my pick-a-part. I bet that wastegate cost more than my entire first turbo project |
$100 brand new*, hard to pass it up considering a used W/G would have been in the $35 or more range
*guy had it listed as a specific car model wastegate for a vehicle that did not come stock with a turbo, I think it scared some people from bidding....
QUOTE |
are you going to use the turbo oil pump mike? |
still undecided on the mounting of the turbo, if I mount it high, no extra pump needed.....if low, then I'll go with the electric pump, not too motivated to pull the motor just to install a brand new stock location oil pump
Andyrew
May 9 2005, 02:56 PM
QUOTE |
$100 brand new*, hard to pass it up considering a used W/G would have been in the $35 or more range |
$350 you mean?
Sweet goin with the snag!
Cant wait till next year when I start my Turbo setup...
Andrew
tnorthern
May 9 2005, 03:12 PM
Ok I don't even want to get involved in this discussion because after all it is impossible... but what the hell. I was think along these lines for a car that has stock sized tires and is running a fresh but stock 2.0. It does seem like a good combo for a small tire/weakish transaxle (I know it can handle some hp I am just thinking bang vs. buck) once the boost comes on you on rolling pretty good anyway... As for location are you thinking the dead space on the passenger side above the axle? It would make it easier to mount an intercooler in the rear trunk and feed it through a 930 type tail
Nevermind you can't turbo a 914 anyway.
Mueller
May 9 2005, 03:22 PM
QUOTE (tnorthern @ May 9 2005, 02:12 PM) |
Ok I don't even want to get involved in this discussion because after all it is impossible... but what the hell. I was think along these lines for a car that has stock sized tires and is running a fresh but stock 2.0. It does seem like a good combo for a small tire/weakish transaxle (I know it can handle some hp I am just thinking bang vs. buck) once the boost comes on you on rolling pretty good anyway... As for location are you thinking the dead space on the passenger side above the axle? It would make it easier to mount an intercooler in the rear trunk and feed it through a 930 type tail Nevermind you can't turbo a 914 anyway. |
of the few 914-turbos that don't exist , the turbo itself has been placed in the following locations with great results:
engine compartment, sitting above the motor,
on passanger side up near the bellhousing (opp. side of starter),
all the way back near the side of the transmission mounting ears....
all of them have worked, no issues with major turbo lag or any of that stuff as long as turbo size is taken care of....
there are Chevy V8's running stock transmissions and "little" 205 sized tires with no problems..most turbo /4's are putting out way less hp/tq so it should be no big deal....even when the boost does come on, it's not like it's going to be an instant 75hp increase that going to shock the drivetrain...
lapuwali
May 9 2005, 03:34 PM
QUOTE (tnorthern @ May 9 2005, 01:12 PM) |
Do some searches here for member airsix. He has a 1.7 with a super-cheap turbo setup on it.
The 914 gearbox really isn't THAT weak. A turbo'd 914 engine is certainly not going to make enough torque to cause any problems unless you went completely insane on it. Figure well under 200ft/lbs, which is quite a bit less than the typical SBC is putting out. I know from personal experience that 150ft/lbs is enough to make the stock 1st gear superfluous, and is quite enough to embarrass the average Mustang GT when employed in a 914.
tnorthern
May 9 2005, 03:36 PM
QUOTE |
My thoughts exactly. The turbo thing more like enforces what I enjoy about driving this car, I have never driven a V8 914 but I would be leary of one with even a 300hp just because of traction slash balance issues. Obviously flared and prepped suspension wise cars would be less of a concern. But you are talking big dollar done right. I built a nearly 500hp small block Chevy for my dad's 69 Vette and while it is a blast to drive, it is highly unpredictable at speed and that is with a 295 tires on the rear. For me at least part of the fun of a 914 is the way parts are balanced together and have a nice feel... of course that said horse power is fun
Andyrew
May 9 2005, 03:45 PM
In this sort of turbo'd car, you'd almost need first gear to get the boost up... or else you would feel a HORRIBLE turbo lag with as wide of a gear as second...
But then again... You dont really want to shift much in a car like a 914.. lol
The turbo, even though it isnt going to make the car a supercar... will probably feel incredibly quick.
with the turbo, having a cointinuous increase in acceleration makes the car feel so fast, its scary.... (with the big turbo on the race car, I found the sweet spot on the throttle, and scared myself half to death a couple times...)
tnorthern
May 9 2005, 03:50 PM
QUOTE |
Do some searches here for member airsix. He has a 1.7 with a super-cheap turbo setup on it. |
Thanks for the tip I'll search for it. I was thinking of the black car with the plate frame "trust me it's stock" can't think of the screen name right now but that set up he has for his intercooler just looks plain sick.
Aaron Cox
May 9 2005, 04:37 PM
QUOTE (tnorthern @ May 9 2005, 02:50 PM) |
QUOTE | Do some searches here for member airsix. He has a 1.7 with a super-cheap turbo setup on it. |
Thanks for the tip I'll search for it. I was thinking of the black car with the plate frame "trust me it's stock" can't think of the screen name right now but that set up he has for his intercooler just looks plain sick. |
maltese falcon....
martys car is FAR from stock
tnorthern
May 9 2005, 04:45 PM
That's it, thanks Aaron. Yeah back in my street racing days we used to do stealth Nitrous set ups and whenever someone wanted to look under that hood we let em. Of course they couldn't look in the trunk that would spoil all the fun....
I've heard the "trust me it's stock/mostly stock/only a 307/mild cam and small four barrel/insert your own made up BS lie here, more than I can count.
iamchappy
May 9 2005, 07:22 PM
This is how I handled the intercooler in my car.
iamchappy
May 9 2005, 07:23 PM
top
iamchappy
May 9 2005, 07:25 PM
scoop in the spoiler for fresh air.
iamchappy
scoop
iamchappy
May 9 2005, 07:26 PM
spoiler grill
iamchappy
May 9 2005, 07:27 PM
these suck the air through 7" electric fans
iamchappy
May 9 2005, 07:32 PM
I use a Tial 38MM wastegate and a 50mm Tial BOV, I use a Turbo X boost controller to adjust the boost.
I hope this helps.
Britain Smith
May 9 2005, 07:34 PM
QUOTE (iamchappy @ May 9 2005, 06:32 PM) |
I use a Tial 38MM wastegate and a 50mm Tial BOV, I use a Turbo X boost controller to adjust the boost. I hope this helps. |
How often did you actually tweek the boost? I am trying to decide if I need to get a boost controller right now or if I will be fine with setting it at a certain value and worring about other things.
I am also going to use Tial wastegate and BOV.
-Britain
iamchappy
May 9 2005, 07:51 PM
I rarely tweek, the controller is in the engine bay once its set it stays there. Was set at 9lbs last year without an intercooler, with the intercooler I was hoping to tweek it up to maximum of 14.
Dave Blackburn
May 9 2005, 08:44 PM
Hey guys.
I just got a book called "Maximum Boost" for a turbo Bug project I am planning.
I haven't read the whole thing yet, but it seem good and has lots of info and calculations.
Good luck!! Sounds like lots of fun!!
http://www.amazon.com/exec/obidos/search-h...9241430-2958269Check out what a "maximum boost" search returned on amazon, #5......
Later,
Dave
914_1.8t
May 10 2005, 10:29 AM
Mike, what turbos are those? Got any specs and/or compressor maps?
Mueller
May 10 2005, 11:37 AM
QUOTE (914_1.8t @ May 10 2005, 09:29 AM) |
Mike, what turbos are those? Got any specs and/or compressor maps? |
stock TD04-09B-6cm2 turbo from a Mistu 3000GT/Dodge Stealth twin turbo
