Pics can be found here..(same Username)
http://forums.pelicanparts.com/porsche-914...tml#post9258254
Think I have everything I need, now I’m clearing out the rest of the parts I have collected as part of my project. Prices are plus shipping unless noted as “shipped”. Add PP fees if sending not as a friend. Let me know if there is anything pictured that you need but is not listed. I apologize to those who asked for some of these things, I just had to go through and decide what I needed before listing the rest..Everything should be fairly priced to move to a new home garage. Everyone appeared to be happy with the last round of stuff. Let me know if I’m off the farm on anything.
**Important** All Paypals need to have the buyers screen name, the items they are buying and the shipping address listed in the notes. If not they will be refunded because it’s a huge PITA to keep straight with this many items.
Thanks guys! (and gals, I have learned). Keep on turning those wrenches!!!
REDUCED PRICE Factory front and rear sway bars-Need new bushings but include all links as well as the insanely expensive balled shock bolts. $400 (shipping included)
Steering wheel and horn pad- It’s the 380MM wheel! Needs to be recovered. Had planned on doing leather. Pad is crazy nice with no broken ears. $125 (shipped)
Brakes Front and rear- Fronts are the bigger calipers. Painted red (uggg failing paint) both F&R worked great and have nearly new pads. Include lines $200/set (shipped)
Targa Bar Bright work Trim-Very nice. Only missing Pass side rear sail trim, $60
Set of Dash Swithches-$75 (shipped)
Speaker housings with newer Speakers, No broken tabs-$50
SOLD Bottom Dash Pad- Fantastic condition, aluminum trim, Side vents included. Two small splits inder glove box..1/16 inch. Invisible unless looking for them. $80 (figure about $20 shipping in the US.)
Relay Board, Relays and Cover, 73 2.0- $50
Heater Blend boxes (front), Defrost vents and lower vents Very nice finish on metal $65
Cabin Heater Controls $60 (Shipped)
Rear Lights-Pair-(no lenses) VERY nice Finish. Very little distortion around centers. One outside reflector. $75 (Shipped)
1.7/1.8 Engine Tins, Set. Nice shape, Been painter. $75
Rocker Jack post supports. New. In Primer $20 (Shipped)
SOLD Stainless Rockers, No jack holes. $50
SOLD OEM Steel Rockers. A little rough but should be fine with a blast and paint. $50
Center Seat pad with flip up lid. Rip in top, otherwise very nice $20
Headlight Motor Set $50/pair
Headlights Complete mechanism, bulbs, motors, surrounds, covers, trim, all hardware. Nice set to restore or paint to match and use as is. $150
Transmission Speedo drives $25/ea (shipped)
Clutch fork 915/901 $20
Back Pad for dual adjustable seats. Has couple rips. Board is good. Fix or use for parts, recover, custom. $80
Seat rails (PAIR)-and all hardware, missing one adjuster handle, 1 new one though. $80
Heater Control Boxes (Clam shells) Surface rust on one. Both function and spring correct. $55/pair (shipped)
Silver dot gauge cluster- 150mph speedo. Decent shape could use a resto $100 (Shipped)
Silver Dot 73 only Multi-gauge $150 (shipped)
Wing Windows frame and Rubber- Include hardware, nice shape. $45 (pair)
Side Window glass $40 ea.
Widow Regulators $30/each
Targa Top- Latches, chipped corner, Good Headliner and underside chrome. OK Shape for driver $65 (figure on at least $50 shipping).
Rear Trunk lid- Very clean $75 (Local preferred)
Door Shells, fairly clean, $75/ea
Dash Frame (buck) Clean $50
Door cards, one split in top roll, all metal hangers intact. Nice condition front and back $50
Outside Door Handles, Locks, Trunk button and front trunk handle,cable and lock. OEM black Key. $150
Door sill alum plates $30
Round side marker lights, seals and un-cracked lenses, buckets (might be new lenses) Hella $40 (Shipped)
