QUOTE(rgalla9146 @ Aug 30 2016, 02:07 PM)
QUOTE(xsurfer @ Aug 30 2016, 03:31 PM)
I have a 71 six that the oil lines leak (what's new). Is there a method to
stop the only line leaks. When we took the engine out we could barely get
the lines apart.
Is torque the answer? Can teflon tape stop the leaks?
Thanks
Gene
Has your oil plumbing been changed from stock ? stock tank ?
No Changes, stock 88K miles.
Check for deterioration on the inside of the female receivers and the outside of the
male fittings. Dings, grooves,rust etc. can interfere with sealing.
I've never heard of inferior replacement hoses.
Teflon tape is for tapered pipe thread. It has no place here.
Are you certain the leaks are from the fittings ? not the hose portion ?
Do your hoses still have aluminum collars ?
