Hey Ross,
Member vendor Mark/Mikey914/914Rubber sells their better-than-original repro F & R pads, both using SS hardware so nothing inside will rust away like the OE ones did, & the surface texture & finish is concours perfect, but made from better plastic "rubber" compounds.
Check with him if he has any 914world discount or GB for them.
PS - Auto Atlanta also sells some repros they make, if you want a place closer to you in NC.
- I think the ones at Stoddard's in Ohio are 914Rubber's, but double check with Mark.
Tom
