'75 2.0. Just put in a new bosch fuel pump (and filter) because the old pump started making a lot of noise and I assumed it was dying. The PO had removed the black/red wire that goes from the + on the pump to the relay board and instead ran a red +12v wire to somewhere that kept the fuel pump running at all times, even if the car didn't start.
With the black/red wire connected now, the pump runs for 1 second or so before cutting off as it should. However, I can't get the car to start. (No issues previously). Feels like it's being starved of fuel. At one point I got it running for a solid 6 or 7 seconds, but it was close to stalling the entire time and the fuel pump stopped running after the initial 1.5 seconds or so. Shouldn't it have been running even if the car stumbling?
If I recall the ECU in my car is from a '74 or a '73. (came with this when I bought it). Engine had been rebuilt and smog stuff removed. Any chance the ECU not being the correct model is the problem here?
I haven't had time to check for a crimped fuel line under the tank yet, but doubt that's the issue given all was good prior to replacing the pump and rewiring it. Really feels like the pump just isn't staying on long enough for it to run.
