Dion
May 13 2025, 08:36 AM
Come together
Dion
May 13 2025, 08:37 AM
Mating case halves
Dion
May 13 2025, 08:38 AM
Pistons and barrels on
Dion
May 13 2025, 08:41 AM
Getting there
Dion
May 13 2025, 08:43 AM
930 tensioners with safety collars:
Dion
May 13 2025, 08:45 AM
Rockers in & valves adjusted:
Dion
May 13 2025, 08:47 AM
It’s looking more like a complete powerplant.
Dion
May 13 2025, 08:48 AM
Bottoms up
Dion
May 13 2025, 08:50 AM
Came to find out , my engine never had a cozy cone. Now it does!
Dion
May 13 2025, 08:51 AM
Almost there
Dion
May 13 2025, 08:53 AM
On the test stand
Dion
May 13 2025, 09:02 AM
Building pressure 20 to 60 to 80psi 30weight break in oil.
https://youtube.com/shorts/ZRLZRBSk6u0?si=8c9RuF5NqY9gPfQI
Dion
May 13 2025, 09:09 AM
Dion
May 13 2025, 09:12 AM
Dion
May 13 2025, 09:15 AM
So plan is to mate to chassis this Thursday. Need to put some miles on and then redo
valve adjustments.
Will be participating in Ruchlos Rallye with some of 914Mob. Looking very much forward to this.
Thanks for looking in!
Root_Werks
May 13 2025, 09:50 AM
Awesome progress! It's so nice to run an engine on a stand before installing it.
TJB/914
May 13 2025, 10:41 AM
Dion,
Congratulations
Tom
Dion
May 13 2025, 10:54 AM
Thanks Dan & Tom.
I’m quite surprised at how well the engine ran prior to this rebuild.
In addition to the sad valves on #4, all the valve guides were worn, valves had to be replaced & the case had someone in there before. Found evidence of Mr Rod knocking.
It’s had a tough life. We will now treat with some respect.
Porsche built some tough engines that’s for sure.
Cairo94507
May 13 2025, 11:02 AM
Congratulations Dion; sounds really nice. Good luck on the install Thursday.
May 13 2025, 01:13 PM
QUOTE(Dion @ May 13 2025, 12:54 PM)
Thanks Dan & Tom.
I can’t wait to hear feedback comparing before and after.
BeatNavy
May 13 2025, 04:08 PM
That's excellent, Dion
Hopefully I'll get a chance to hear it later this summer.
rgalla9146
May 13 2025, 04:33 PM
Hey Dion
Well done !
Sounds great.
Looking forward to NEG and seeing in person.
Rory
PS no mention of those con rods ? I'm not tellin'
friethmiller
May 13 2025, 04:38 PM
Yeah baby! She's alive!
Dion
May 27 2025, 05:50 AM
Ok, back on track. Shout out to
@TonyA for bringing the chassis to the shop.
A few days of fettling, engine mounted, wiring began, linkage etc.
Carbs were quite a challenge. To get to that sweet spot for “most” driving conditions.
Dion
May 27 2025, 05:52 AM
Flywheel/clutch
Dion
May 27 2025, 05:53 AM
Ready for lifting
Dion
May 27 2025, 05:56 AM
So too busy installing, no pics of that but, once done. We sent it to get alignment.
New Pirelli on board.
Dion
May 27 2025, 05:59 AM
A good buddy of mine Dave Tr. picked it up for me. Gave her a drink & brought back to the shop.
Dion
May 27 2025, 06:04 AM
So more fiddling at the shop for carb adjustments and fixing tach signal plus timing.
Was able to take home. Runs like a banshee.
Well pleased. Now to get some details addressed. Wire wrapping and layout, fixing some
headlights that decided to work when they feel like it, plus the air hoses for heat.
Here’s a vid:
https://youtu.be/jFl-6Xdy_6o
mate914
May 27 2025, 06:12 AM
QUOTE(Dion @ May 13 2025, 10:30 AM)
Timing gears on IMS and polished chains.
Dion, Why do they polished the chains?
Matt
Dion
May 27 2025, 06:14 AM
Matt I was told it was for minimizing frictional losses.
Cairo94507
May 27 2025, 06:40 AM
Congratulations Dion; that is a beautiful car.
nditiz1
May 27 2025, 06:43 AM
Looks to be ready for RR5!
tygaboy
May 27 2025, 07:37 AM
Dion! WOW, your car looks great!
Congrats!
JmuRiz
May 27 2025, 07:39 AM
What a looker, congrats!
May 27 2025, 07:55 AM
I don’t hear 7K yet - LOL.
Dion
May 27 2025, 08:45 AM
Thanks a lot fellas! I really appreciate the compliments and good karma.
It’s definitely a different engine from prior previous year.
@mepstein , you should hear it screaming this afternoon when I stop down.
Maltese Falcon
May 27 2025, 09:12 AM
Dion the vid is on Point ! Love the car + countryside drive
Marty
gereed75
May 27 2025, 10:58 AM
Beautiful car and love the engine choice! Something about the smaller displacement motors that really compliment the spirit of these car, for me anyway.
Sweet!!
mate914
May 28 2025, 06:49 AM
QUOTE(Dion @ May 27 2025, 10:45 AM)
Dion,
So, your engine was a aluminum block someone put T or E pistons in, 30+ years ago?
Now it is a 2.4S+?
Engine sounds great. I am leaning also, so I have a few questions.
1 What compression?
2 what valve springs did you use to achieve 7K RPM?
3 Distributor advance?
4 85mm or 84mm pistons?
5 What camshaft?
Thanks,
Matt
Dion
May 28 2025, 07:37 AM
@mate914 '67 sandcast case, Biral cylnders, JE 85mm pistons,10.1 compression, E cams, Billy Ring machine shop did the heads. I do not know the exact specs on valve springs. i believe we set advance at 10*. It has a 123distributor.
Cheers, Dion
sb914
May 28 2025, 08:09 AM
Very beautiful car .
May 28 2025, 08:21 AM
QUOTE(Dion @ May 28 2025, 09:37 AM)
Cheers, Dion
Performance valve springs (a notch more than stock) and machine work done by Billy at Performance auto works in kearneysville WV.
porschetub
May 28 2025, 03:58 PM
QUOTE(Dion @ May 29 2025, 01:37 AM)
Cheers, Dion
Looks great buddy,you must be pleased to see thay "saga" behind you ,time to tell us about the lovely con rods ...time to fess up lol, best regards mate.
OrangeBones
May 28 2025, 06:41 PM
Can’t wait to have you in my mirrors at RR5! She sounds amazing! Glad the fellas were able to get us ready in time!
Dion
May 28 2025, 10:15 PM
@sb914 Thank you!
@orangebones Yes looking forward to this Rallye.
@porschetub Dean, thanks my friend. Con rods ? Oh those little Pauter things?
Just a little somethin’ somethin’
@rgalla9146 Rory you & Dean zeroed in on those con-rods
@gereed75 Thanks buddy, yeah I think the 2.4 should have been the standard 6 for the 914. Seems made for it, IMHO.
@Maltese Falcon Thanks Marty!
Doing a punch list before this rally. Bolts to be torque’d, spare wipers, bulbs, fuses, fuel pump, tool kit, oil, etc.
gereed75
May 29 2025, 07:42 AM
Matt
I basically have the same motor except 9.5 JE pistons and DC30 mod Solex cams. Really like the cams. Good low end power with a nice almost S top end kick.
Stock rods and valve train. Revs to 7200 no problem.
