Made specifically for the 914, this is a heavy duty steel angle cross bar design rather than flat bar found on previous product.
This provides key advantages:
1st. Strength.
2nd. Geometry.
The new x-bar also allows the pin lynch points to be about 1" lower then before (while actually improving its strength).
3rd. Convenience!
The bar now has mount points to carry the included bolts & spacers.
Because it has its pin/bar mounting location slightly lower, allows for use with "LE" style FG spoilers without their removal (with properly setup hitch & bar geometry!).
The V style adj. tow bar is recommended again for its convenience, as you can fold it up & throw the whole kit in the either trunk!.
The Bar is made from .375 steel & still relatively light weight.
Lastly it also has additional mount points for chassis safety chains /cables.
FITS ALL 914's regardless of MY!
Designed to use the inexpensive Adjustable V tow bar - NO Adapters necessary!
*If you still run the OE steel valance it will still be necessary to remove before use.
The Tow bar & lights (pictured below) can be provided/purchased as a bundle for your convenience, but are readily available from many sources.
914 chassis mount bar HERE
914 Tow Kit (mount bar & adj. V hitch bar + lights) inquire
Magnetic Tow lights HERE
