PanelBilly
Sep 9 2016, 06:55 PM
Should have done this from the start, but I thought I knew better. If you're going to have a six then cut the hole in your firewall when you're doing the body work. Swapping out the shims for adjusting the tension on the fan belt is so much easier when you can see what you're doing. I plan to add some tabs to the peice I cut out and fix it so it will bolt back into place.
euro911
Sep 9 2016, 07:27 PM
Billy, just an idea
... have you thought placing a WTB ad for someone to cut you a larger firewall section out of a scrap car, so you can trim it to size with an overlap to the opening you cut?
GaroldShaffer
Sep 9 2016, 07:46 PM
QUOTE(euro911 @ Sep 9 2016, 08:27 PM)
Billy, just an idea
gee I wonder who would have something already cut out that you could use.
Mark Henry
Sep 9 2016, 09:26 PM
Plus I would have made it bigger.
It will be hard to get you hand in there to turn the dizzy, while holding a strobe aimed at the timing marks and trying to see what you're doing.
Krieger
Sep 9 2016, 09:31 PM
Cool! A buddy convinced me to do it on my track car. I am so glad I did it you will be too. It is also handy when setting your timing. I do not have a back pad so it is just a few screws to remove.
PanelBilly
Sep 9 2016, 10:27 PM
I have the flywheel marked for timing but it would be nice to check it on the crank
Krieger
Sep 9 2016, 11:09 PM
I do too, but you can do it so much quicker sitting in the driver's seat glancing at the tach and looking at the timing marks. Easier to get at the distributor bolt too.
mb911
Sep 10 2016, 09:58 AM
When folks mention a larger hole how large are we talking? I will do this on my car at some point but just curious what people feel is big enough..
Larmo63
Sep 10 2016, 10:51 AM
I'm doing this on Blackie. I bought a section at the last swap to do it.
