sdoolin
Sep 10 2016, 02:17 PM
Subject line says it all. I have money burning a hole in my pocket for distributor for my 2056 build. It will run dual Dellorto 40's. I have been told that the Mallory Unilite is the way to go, but (as you all know) it is NLA. Maybe someone has one on a shelf somewhere?
If there are other good option I am all ears.
This is THE LAST BIT that I need (I think) for my build. I'm beggin' here...
MarkV
Sep 11 2016, 12:55 AM
If you can find a used Mallory dual point or single point distributor you can buy a Unilite retrofit kit or better yet a Pertonix II retrofit kit. The dual pooint or single point are the same distributor at the Unilite the only difference being the Unilite pick-up plate. I picked up a new dual point on Ebay cheap and converted it to a Pertonix II. At the time the gray springs were still available....might be hard to find now. Last I heard Aircooled.net had some available.
Mueller
Sep 11 2016, 08:43 AM
