QUOTE(napasteve @ Sep 11 2016, 08:44 PM)
I'm going to need to reread Larmo's post a couple more times before I really appreciate my anti-sway bars. Dude knows his stuff.
One big thing to consider when you add a front and or rear sway bar is the spring rate.
Transfer of the weight during braking ect... Dave is correct, the sway bar adds to the spring rate and should be considered in the calculation. There are online spring rate calculators that work pretty well.
I ended up redoing all my shocks tie rods and springs when I added a front sway bar. I also ended up using adjustable drop links which are a must if you want to prevent pre-loading the bar.
Make sure if you are considering it is to make the change to the turbo tie rods as well. The difference in handling and responsiveness is HUGE.
In my opinion for street use and spirited driving a rear bar is not necessary.
