andrewvolsen
Sep 12 2016, 02:39 PM
I need a throttle body (or maybe just the brass throttle plate?) for a 1974 1.8. My throttle body sticks a bit when completely shut and I can't adjust the idle high enough using the air bleed screw. I think that a PO modified the throttle plate to seal tighter in the bore than it did originally in an attempt to compensate for vacuum leaks (all of which I have now eliminated).
